Duplicate entry folder mapping
Ray
I have duplicate folders which I seem to be unable to merge. See attachment.
This is probable a result of relinking an UNC path (\\server\Collectie) to the local drive (I:\\Collectie).
I get this difference when adding pictures from my laptop instead of the server (which is my desktop). My laptop has a mapping to drive I: but that is not used when uploading.
How to solve this?
I would also like to see a solution for this difference in folders when adding pictures, because it is a bit annoying.
Cheers
  • 4 weeks later...
Sorry, hadn't looked earlier...
What do you mean with "merge folders"?
If I use Daminion on the pc with server I have two similar drives. I cannot merge them.
It says: "Source and destination path must be different"
Ray
