Import Drive and exclude specific folders
GasEngine
If folders that you want to exlude have unique names and there you don't have another folders with the sames names you can add these folder names into your Exclusion list in your "Catalog > Import Filters > Ignore these files and folders" file mask.
  • 5 weeks later...
Didnt want to start another thread as its related and thought i would also point out that if you do a F6 rescan it will also import your excluded folders, in my case im trying to exclude "_Rejected\"
You also cannot exclude folders starting with a full stop "." e.g. ".picasaoriginals\" it pops up an error saying invalid exclude filter.
  • Upvote 1
  • 1 month later...
picasaoriginals folder is excluded by default.
In the upcoming Daminion build you can exclude folders that contains the dot "." symbol and a minor bug with exluding folders will be fixed.
I am using Build 1269 but i still have the problem wiht the import filter.
I have added this string to the "Ignore these files and folders:" -> "!Auftrag; doc_ps_pdf"
Still the "!Auftrag" folder gets scanned.
  • Upvote 1
