1194 - synchronization Tag Presets, Properties Panel and Catalog Panel
Uwe
the Properties Panel depends on the media format. E.g. one can't see the Audio chapter if the media format of the selected item = JPG and one can't enter audio data (artist) in a photo item.
But it's possible to assign Audio metadata to an image item by the Tag Preset Window or in the Catalog Panel. To remove these audio metadata from the image item one has to use the Catalog Panel because they don't appear in the Properties Panel of the image item.
My question: is it a bug or just an open issue to synchronize the Tag Preset Window, Catalog Panel and Properties Panel regarding the option to enter metadata. Or, maybe it make sense to have these options?
