CSV import problem
sig285
Hi there,
if i import data from CSV-File, Daminion 3.7.0 (build 1187) doesn't import the "description" field. It is always empty.
I tested it with this simple example.
FilePath;Rating;Keywords;Description
C:\Test\Images\Image1.jpg;1;keywords\keyword1;description1
  • 11 months later...
(I doesn't open a new topic : sorry if I should !)
I'm trying to import metadatas from a CSV File (1512 items).
FilePath;Item Id;Description
\\serveur-2008\PATH\MEDIA.jpg;88416;description1
\\serveur-2008\PATH\MEDIA.jpg;88417;description2
FilePath was written from an export of Daminion Catalog.
Strangely, the search found 0 file (1512 missing files).
I am wondering if it's in relation to external path (\\serveur...)
Thanks for your help !
Sylvain M.
