Add images to tray does not work in "view" mode
Guardian
It is a shared catalog.
- I am doubleclicking an image, press insert and close the preview -> nothing in tray
- I am doubleclicking it again, right click -> Add/Remove from Tray -> close the preview -> it is in the tray
I am on build 1193. I can't find 1194 in your dropbox.
Now (build 1196) [ins] key from full view add item in Tray (Good) but green triangle is not displayed in full view.
Without green triangle dispalyed, you do not know if your item has been added or not, this can be confused because if you press twice [ins] key this remove item from Tray.
A green triangle display gives you confirmation.
