Uwe Posted March 4, 2015 Report Share Posted March 4, 2015 Hello, both functions don't work. I've inserted with build 1175 some items to the Tray. Now opening the catalog, some items are duplicated in the Tray. I cant't assign new items to tre Tray and I can't remove items from the Tray. When I switch in the Tray from the Thumbnail View to Filmstrip View sometimes I get an exception - try to reproduce it. The video is on the FTP folder. Regards, Uwe Update: one has to clear the Tray and now it works until you change the selection you made in the Catalog Panel. Then this bug appears: The Tray is empty. I select a collection_01 and assign the items of this collection_01 to the Tray. Then I select another collection_02 in the Catalog Panel or I select another tag, e.g. Keywords and at the moment the selection in the Catalog Panel changes the entries in the Tray are duplicated. And now I can't ADD or DEL items to/from the Tray Quote Link to comment Share on other sites More sharing options...
