kalain Posted March 3, 2015 Report Share Posted March 3, 2015 Hi, Last time, I made few pictures of an event and wanted to make a selection to send it by mail to a friend. So, I added these pictures to Daminion in a specific folder. Browse them in full view mode and missed the possibility to insert some of them in Tray by 'Ins' key. (Already reported in another topic here) Anyway, in full view mode (displayed from main thumbnail windows) it would be nice to display a green triangle for items selected in Tray. This would help a lot to see which one are already in Tray while browsing. Regards 1 Quote Link to comment Share on other sites More sharing options...
kalain Posted March 31, 2015 Author Report Share Posted March 31, 2015 A little bump for this one which can be considered as a feature request or a bug. :smile: Quote Link to comment Share on other sites More sharing options...
kalain Posted May 3, 2015 Author Report Share Posted May 3, 2015 Anyway, in full view mode (displayed from main thumbnail windows) it would be nice to display a green triangle for items selected in Tray. This would help a lot to see which one are already in Tray while browsing. As from full view, you can use [ins] key to add items in Tray window, it would be useful to display a green triangle in full view when this item is (already) in Tray. Quote Link to comment Share on other sites More sharing options...
Murat Posted May 5, 2015 Report Share Posted May 5, 2015 I've added this feature into the short roadmap for 4.0 version. It should be implemented soon. Quote Link to comment Share on other sites More sharing options...
kalain Posted May 13, 2015 Author Report Share Posted May 13, 2015 I've added this feature into the short roadmap for 4.0 version. It should be implemented soon. Ok, partial feature has been added in build 1213 but not yet fully completed. In full view (from thumbnail view), you can add item in Tray with [ins] key but no green rectangle is displayed. Also, when in full view (from thumbnail view), you browse an item already in Tray : - a green rectangle is displayed (ok, good) - if you use [ins] key, you remove it from Tray (ok, good) but green rectangle is still displayed in full view! (which shouldn't be ?) Few things to fix here to be fully useable. Quote Link to comment Share on other sites More sharing options...
