Mel Posted January 18, 2015 Report Share Posted January 18, 2015 I'm struggling with the Daminion/DxO tandem. In short, my workflow: 1. Import raw (DNG) photo files to Daminion. 2. Flag green those I want to process. 3. In Daminion: right click > open with > DxO... 4. In DxO: process, save to disc (the same folder). 5. Back to Daminion: rescan folder to import newly created tiffs. Ta-daaa: the problem begins: Now in Daminion I mark the processed DNG file with brown label and in a few seconds the DNG file disappears from DxO list. In order to see it again I have to click another folder, and click my photos folder again. Then I see my lost DNG file for a short while with the name changed to: filename.DNG._00_ This extension is visible in DxO only. Unfortunately, the "_00_" extension persists despite my efforts and I cannot edit the affected dng file any more. Daminion options: default "Write tags to sidecar .xmp files" setting. Any ideas? What's your proven and well-working workflow for Daminion/DxO pair? Thanks for reading, -- M. Quote Link to comment Share on other sites More sharing options...
Murat Posted January 18, 2015 Report Share Posted January 18, 2015 The "Write tags to sidecar .xmp files" works for all Camera RAW images except the DNG files. Daminion always writes directly into the DNG files. I reproduced your issue on my PC. After updating the DNG file in the Daminion I see the filename.DNG in the Windows Explorer, but it is displayed as filename.DNG._00_ in the DxO and unfortunately I don't know what's behind of this logic of the DxO. Quote Link to comment Share on other sites More sharing options...
Mel Posted January 19, 2015 Author Report Share Posted January 19, 2015 I reproduced your issue on my PC. [...] Thank you, Murat. I've published this issue on DxO forums here: http://forum.dxo.com/index.php/topic,10017.msg55856.html -- M. Quote Link to comment Share on other sites More sharing options...
