Antys Cost Posted December 5, 2014 Report Share Posted December 5, 2014 Good morning from Greece. First, when i create a contact sheet with .eps file the program crash. It can not generate pdf the .eps file, stuck there, i can not cancel it and i close the program from windows task manager. Second, without .eps file. Generate .pdf file but the .tif file (and all .tif files that i try) is with huge pixels. Some think happens if i try to print (inside from "create contact sheet") because first generate a .pdf file and then print that file. Also, all imformations from thumbnails captions there are no. Thanks and i am sorry for my bad english :-) (i use daminion 3.5 1128) Quote Link to comment Share on other sites More sharing options...
Murat Posted December 9, 2014 Report Share Posted December 9, 2014 Can you please send me the eps file(s) which are 100%ly crashed the program. May be this issue is specific to certain EPS files. Unfortunately I can't reproduce it with my EPS files. Did you install the SageThumbs and GhostScript according to this tutorial? https://daminion.net/tutorials/ai-eps-support Quote Link to comment Share on other sites More sharing options...
Antys Cost Posted December 10, 2014 Author Report Share Posted December 10, 2014 I send you pm Quote Link to comment Share on other sites More sharing options...
Murat Posted December 11, 2014 Report Share Posted December 11, 2014 Both problems (with large TIFF files and vector images) were fixed. Thanks for the sample EPS file and for the detailed bug explanation. Quote Link to comment Share on other sites More sharing options...
Antys Cost Posted December 12, 2014 Author Report Share Posted December 12, 2014 What build must i install? 1128 or 1130? Quote Link to comment Share on other sites More sharing options...
Murat Posted December 12, 2014 Report Share Posted December 12, 2014 This build is not ready yet Quote Link to comment Share on other sites More sharing options...
