exterminador Posted July 29, 2014 Report Share Posted July 29, 2014 Hi, I noticed that on the customize the "Catalog Tags" and "Properties" panels, I have two "Publishing Services" entries. It seems one is from the previous "Experimental Publishing Panel" and the other one is the one that is shown in the "Publish Panel". Is there a way to get rid of the previous Experimental tag / table from the db? Thanks! Quote Link to comment Share on other sites More sharing options...
Murat Posted July 29, 2014 Report Share Posted July 29, 2014 Do you see two "Publishing Services" tags in the Catalog > Custom Tags window? Quote Link to comment Share on other sites More sharing options...
exterminador Posted July 30, 2014 Author Report Share Posted July 30, 2014 Do you see two "Publishing Services" tags in the Catalog > Custom Tags window? Nice! thanks Murat, just deleted it from there! Regards Quote Link to comment Share on other sites More sharing options...
