exterminador Posted July 29, 2014 Report Share Posted July 29, 2014 Hi, I'm trying to publish some pictures to a Dropbox folder, but I'm getting "The connection to the server has been lost" errors. The problem is that the error is not consistent with a specific file/folder, it happens sometimes when assigning the publishing tag to the first 90 files or with the second or third set of files. And, when the error happens, it seems to do a "roll-back" and delete all the previously created files in the file system sync folder. There is no error in the server log, but found this in the client's log file: 2014-07-29 10:35:12,007 [7] DEBUG PicaJet.Daminion.Service.Client.WCF.Command.CreateMediaItemsBookCommand [(null)] Start: (143) 2014-07-29 10:35:13,557 [7] DEBUG PicaJet.Daminion.Service.Client.WCF.Command.CreateMediaItemsBookCommand [(null)] End: (143) 2014-07-29 10:35:13,557 [7] DEBUG PicaJet.Daminion.Service.Client.WCF.Command.GetMediaItemsByBookCommand [(null)] Start: (144) 2014-07-29 10:35:13,638 [36] ERROR ClientProxy [(null)] eventFaultedProxy 2014-07-29 10:35:13,641 [7] ERROR ClientProxy [(null)] CloseProxyBecauseOfException 2014-07-29 10:35:13,641 [7] ERROR ClientProxy [(null)] CloseProxyBecauseOfException: wcfProxy Abort 2014-07-29 10:35:13,647 [7] ERROR ClientProxy [(null)] CloseProxyBecauseOfException: set cachedProxy in null 2014-07-29 10:35:13,647 [7] ERROR ClientProxy [(null)] RethrowWrappedException 2014-07-29 10:35:13,648 [7] ERROR PicaJet.Daminion.Service.Client.WCF.Command.GetMediaItemsByBookCommand [(null)] Error: (144) System.ServiceModel.CommunicationException: The server did not provide a meaningful reply; this might be caused by a contract mismatch, a premature session shutdown or an internal server error. Server stack trace: at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout) at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs) at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation) at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message) Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) at PicaJet.Daminion.Service.WCF.ITransportCatalogService.GetMediaItemsByBook(Guid bookGuid, Int32 pageIndex, Int32 pageSize) at PicaJet.Daminion.Service.WCF.TransportCatalogServiceDynamicClientProxy.GetMediaItemsByBook(Guid , Int32 , Int32 ) at PicaJet.Daminion.Service.WCF.TransportCatalogServiceDynamicProxyWrapper.GetMediaItemsByBook(Guid , Int32 , Int32 ) at PicaJet.Daminion.Service.Client.WCF.Command.GetMediaItemsByBookCommand.Start() in c:\DaminionAuto\Code\Service.Client.WCF\Command\GetMediaItemsByBookCommand.cs:line 30 at PicaJet.Daminion.Service.AbstractCommand.Process() in c:\DaminionAuto\Code\Service\AbstractCommand.cs:line 21 2014-07-29 10:35:13,668 [12] ERROR ClientProxy [(null)] ChannelFactoryOnOpened I was able to reproduce this behavior with two different catalogs. Any ideas what the issue can be? Thanks! Quote Link to comment Share on other sites More sharing options...
exterminador Posted August 9, 2014 Author Report Share Posted August 9, 2014 Hi there, Any ideas on what could be wrong? I tested it again hoping the latest export fixes would also fix the publishing issue I'm having... but I still get the same error with build 1064 :( Anyone using the Publishing feature having any issues with it? Thanks!!!! Quote Link to comment Share on other sites More sharing options...
Murat Posted August 19, 2014 Report Share Posted August 19, 2014 What Transformation preset did you apply to the root publish tag? Can you record a short video for me? Quote Link to comment Share on other sites More sharing options...
exterminador Posted October 11, 2014 Author Report Share Posted October 11, 2014 What Transformation preset did you apply to the root publish tag? Can you record a short video for me? Hi Murat, thanks, it has been a while but I'm sending the video to your e-mail address. I recently updated to build 1090 and was able to reproduce the issue. Thanks!!! Quote Link to comment Share on other sites More sharing options...
