cincytriguy Posted July 8, 2014 Report Share Posted July 8, 2014 I recently installed build 1048 and I have a reproducible cut and paste bug. When I cut a folder and select 'paste as sub-tag' to paste the folder into another folder, it performs the cut and paste within the catalog but does not actually perform the cut and paste on disk. In other words, the catalog shows the folder in the new location, but the actual folder location on disk hasn't moved so now the catalog and Windows Explorer each show the folder as living in 2 different locations. Hopefully this can be fixed soon as I do a lot of cutting and pasting within Daminion and this bug is sure to cause massive confusion as the catalog and my actual folders begin to drift farther and farther out of sync with each other over time. Jason Quote Link to comment Share on other sites More sharing options...
Murat Posted July 8, 2014 Report Share Posted July 8, 2014 Thanks. The bug was registered (#3411) Quote Link to comment Share on other sites More sharing options...
Murat Posted September 26, 2014 Report Share Posted September 26, 2014 Fixed in the 1078 build. Quote Link to comment Share on other sites More sharing options...
