exterminador Posted December 23, 2013 Report Share Posted December 23, 2013 Hi! When trying to create a Custom Tag (or the Publishing Panel) I get the timeout error bellow. It probably happens only with large collections or very slow computers, as the "INSERT INTO CustomNamespaceValues" query can take more than the default timeout value for Daminion (probably just for a few seconds), in my case the insert took 36s while testing it directly on the database. For this scenarios would it be feasible to (temporarily) adjust the timeout value for database connections on the server's config file or something like that? I'm getting pretty good response times for every other operation on Daminion so I guess it only makes sense on this "big" transactions. (I was using build 911 when tested this). Thanks! 2013-12-08 17:20:11,605 [14] DEBUG PicaJet.Daminion.Service.Utils.CreateCustomNamespaceCatalogItemsCommand [(null)] - Start: (46) 2013-12-08 17:20:11,614 [14] DEBUG SQL [(null)] - select ID, Guid, Name, Description, TableName from Namespaces where Guid = @Guid (@Guid=6f7e59ef-3fc0-430f-ae50-a1eb36e017fb) 2013-12-08 17:20:11,634 [14] DEBUG SQL [(null)] - insert into Namespaces (Guid, Name, Description, TableName) values (@Guid, @Name, @Description, @TableName); select lastval(); (@Guid=6f7e59ef-3fc0-430f-ae50-a1eb36e017fb, @Name=custom, @Description=custom namespace, @TableName=CustomNamespaceValues) 2013-12-08 17:20:11,642 [14] DEBUG SQL [(null)] - insert into NamespaceItems (Guid, Name, Description, FieldName, DataType, ID_NameSpace, ReadOnly, GuiType, Units, Multiplier, ExcludeFromUI, PropertyInspectorTitleAlign, TagGroupGuid) values (@Guid, @Name, @Description, @FieldName, @DataType, @ID_NameSpace, @ReadOnly, @GuiType, @Units, @Multiplier, @ExcludeFromUI, @PropertyInspectorTitleAlign, @TagGroupGuid); select lastval(); (@Guid=b9fcd9d6-0b5c-40eb-86fc-f29eae8e03db, @Name=Fixed Filename, @Description=Fixed Filename, @FieldName=Custom_35d34ffd_b999_4577_a410_39b7d031ab3e, @DataType=System.String, @ID_NameSpace=9, @ReadOnly=False, @GuiType=Text, @Units=, @Multiplier=1, @ExcludeFromUI=False, @PropertyInspectorTitleAlign=Left, @TagGroupGuid=6f7e59ef-3fc0-430f-ae50-a1eb36e017fb) 2013-12-08 17:20:11,646 [14] DEBUG SQL [(null)] - select 1 from information_schema.tables where table_schema = 'public' and Upper(table_name) = 'CUSTOMNAMESPACEVALUES' () 2013-12-08 17:20:11,661 [14] DEBUG SQL [(null)] - CREATE TABLE CustomNamespaceValues ( ID_MediaItem bigserial NOT NULL PRIMARY KEY, Custom_35d34ffd_b999_4577_a410_39b7d031ab3e text); () 2013-12-08 17:20:11,796 [14] DEBUG SQL [(null)] - INSERT INTO CustomNamespaceValues (ID_MediaItem, Custom_35d34ffd_b999_4577_a410_39b7d031ab3e) SELECT ID, @Custom_35d34ffd_b999_4577_a410_39b7d031ab3e FROM MediaItems; (@Custom_35d34ffd_b999_4577_a410_39b7d031ab3e=) 2013-12-08 17:20:12,960 [sTP SmartThreadPool Thread #1] DEBUG PicaJet.Daminion.Service.Utils.GetSynchronizeStateCommand [(null)] - Start: (47) 2013-12-08 17:20:12,963 [sTP SmartThreadPool Thread #1] DEBUG SQL [(null)] - select count(*), sum(case when Offline or Processed then 0 else 1 end) from (select distinct s.ID_MediaItem as ID_MediaItem, m.Deleted, f.Offline, s.Processed from Synchronize s left join MediaItems m on (s.ID_MediaItem = m.Id) left join Files f on (s.ID_File = f.Id)) vv () 2013-12-08 17:20:12,965 [sTP SmartThreadPool Thread #1] DEBUG SQL [(null)] - delete from Synchronize where Id in (select s.Id from Synchronize s left join MediaItems m on s.Id_MediaItem = m.Id where m.Deleted) () 2013-12-08 17:20:12,967 [sTP SmartThreadPool Thread #1] DEBUG PicaJet.Daminion.Service.Utils.GetSynchronizeStateCommand [(null)] - End: (47) 2013-12-08 17:20:23,101 [sTP SmartThreadPool Thread #1] DEBUG PicaJet.Daminion.Service.Utils.GetSynchronizeStateCommand [(null)] - Start: (48) 2013-12-08 17:20:23,114 [sTP SmartThreadPool Thread #1] DEBUG SQL [(null)] - select count(*), sum(case when Offline or Processed then 0 else 1 end) from (select distinct s.ID_MediaItem as ID_MediaItem, m.Deleted, f.Offline, s.Processed from Synchronize s left join MediaItems m on (s.ID_MediaItem = m.Id) left join Files f on (s.ID_File = f.Id)) vv () 2013-12-08 17:20:23,118 [sTP SmartThreadPool Thread #1] DEBUG SQL [(null)] - delete from Synchronize where Id in (select s.Id from Synchronize s left join MediaItems m on s.Id_MediaItem = m.Id where m.Deleted) () 2013-12-08 17:20:23,119 [sTP SmartThreadPool Thread #1] DEBUG PicaJet.Daminion.Service.Utils.GetSynchronizeStateCommand [(null)] - End: (48) 2013-12-08 17:20:31,857 [14] ERROR PicaJet.Daminion.Service.Utils.CreateCustomNamespaceCatalogItemsCommand [(null)] - Error: (46) Npgsql.NpgsqlException: A timeout has occured. If you were establishing a connection, increase Timeout value in ConnectionString. If you were executing a command, increase the CommandTimeout value in ConnectionString or in your NpgsqlCommand object. at Npgsql.NpgsqlState.ProcessBackendResponsesEnum(NpgsqlConnector context) in C:\projects\Npgsql2\src\Npgsql\NpgsqlState.cs:line 382 at Npgsql.NpgsqlReadyState.QueryEnum(NpgsqlConnector context, NpgsqlCommand command) in C:\projects\Npgsql2\src\Npgsql\NpgsqlReadyState.cs:line 67 at Npgsql.NpgsqlConnector.QueryEnum(NpgsqlCommand queryCommand) in C:\projects\Npgsql2\src\Npgsql\NpgsqlConnector.cs:line 292 at Npgsql.NpgsqlCommand.GetReader(CommandBehavior cb) in C:\projects\Npgsql2\src\Npgsql\NpgsqlCommand.cs:line 591 at Npgsql.NpgsqlCommand.ExecuteNonQuery() in C:\projects\Npgsql2\src\Npgsql\NpgsqlCommand.cs:line 495 at PicaJet.Daminion.Service.DbCommandWrapper.ExecuteNonQuery() in c:\DaminionAuto\Code\Service.DB\DbCommandWrapper.cs:line 41 at PicaJet.Daminion.Service.Utils.CreateCustomNamespaceCatalogItemsCommand.CreateCustomValuesTable(DbConnection connection, NameSpaceInfo customNamespace, List`1 namespaceItems) in c:\DaminionAuto\Code\Service.Utils.Uni\Command\CreateCustomNamespaceCatalogItemsCommand.cs:line 140 at PicaJet.Daminion.Service.Utils.CreateCustomNamespaceCatalogItemsCommand.Start(DbConnection connection) in c:\DaminionAuto\Code\Service.Utils.Uni\Command\CreateCustomNamespaceCatalogItemsCommand.cs:line 73 at PicaJet.Daminion.Service.DbCommandExecutor.ExecWithTransaction(Execute execDelegate, IDatabaseEnvironment databaseEnvironment, DbConnection connection, Boolean processErrorHandler) in c:\DaminionAuto\Code\Service.DB\DbCommandExecutor.cs:line 55 at PicaJet.Daminion.Service.DbCommandExecutor.ExecWithTransaction(Execute execDelegate, IDatabaseEnvironment databaseEnvironment, Boolean processErrorHandler) in c:\DaminionAuto\Code\Service.DB\DbCommandExecutor.cs:line 23 at PicaJet.Daminion.Service.DbCommandExecutor.ExecWithTransaction(Execute execDelegate, IDatabaseEnvironment databaseEnvironment) in c:\DaminionAuto\Code\Service.DB\DbCommandExecutor.cs:line 14 at PicaJet.Daminion.Service.Utils.DatabaseCommand.StartWithTransaction() in c:\DaminionAuto\Code\Service.Utils.Uni\DatabaseCommand.cs:line 111 at PicaJet.Daminion.Service.Utils.DatabaseCommand.Process() in c:\DaminionAuto\Code\Service.Utils.Uni\DatabaseCommand.cs:line 40 2013-12-08 17:20:33,225 [sTP SmartThreadPool Thread #1] DEBUG PicaJet.Daminion.Service.Utils.GetSynchronizeStateCommand [(null)] - Start: (49) Quote Link to comment Share on other sites More sharing options...
Murat Posted December 23, 2013 Report Share Posted December 23, 2013 Added to the bug-tracking system (#2947) Thanks for the detailed info! Quote Link to comment Share on other sites More sharing options...
