kalain Posted November 9, 2013 Report Share Posted November 9, 2013 Hi, Drag and drop to a folder is not displayed updated when using a filter with 2 parameters. If you display only Jpeg from a folder (2 filters conditions), now if you drag and drop a file onto another folder, dropped file is still display from origin folder. Regards Quote Link to comment Share on other sites More sharing options...
Murat Posted November 11, 2013 Report Share Posted November 11, 2013 This works only for one selected folder only. Quote Link to comment Share on other sites More sharing options...
kalain Posted December 21, 2013 Author Report Share Posted December 21, 2013 This works only for one selected folder only. Not very cool. Would be nice to extend this (Drag and drop) when a folder is selected and then also when another criteria is selected. (like Jpeg, Lens, Notation or whatever.) Quote Link to comment Share on other sites More sharing options...
kalain Posted January 16, 2014 Author Report Share Posted January 16, 2014 Drag and drop to a folder is not displayed updated when using a filter with 2 parameters. Any plans to fix this ? Quote Link to comment Share on other sites More sharing options...
Murat Posted January 17, 2014 Report Share Posted January 17, 2014 A customer can assign images one by one without lossing the current view. So we can't change this behaviour for other tags. Quote Link to comment Share on other sites More sharing options...
kalain Posted January 18, 2014 Author Report Share Posted January 18, 2014 A customer can assign images one by one without lossing the current view. So we can't change this behaviour for other tags. As I'm also a software developper, I get same kind of problem when drag and drop items from a list to another one. So technically, I do not see what is the problem here. Here is what I do in such case : 1/ Memorize first selected thumbnail position in the thumbnail list 2/ Apply filter (Refresh screen) 3/ Apply focus at thumbnail position memorized Technically, this shouldn't be very different in Daminion ? Regards Quote Link to comment Share on other sites More sharing options...
