Sedat Posted October 5, 2013 Report Share Posted October 5, 2013 Changing the sort order in catalog panel doesn't work. Quote Link to comment Share on other sites More sharing options...
_noel_ Posted October 5, 2013 Report Share Posted October 5, 2013 Changing the sort order in catalog panel doesn't work. Hello Rawshooter, Can you explain ? changing sort order works fine with my (old) catalog and build 889 klicking on the arrow button in the bottom button panel, also changing the "sort by" criteria. Regards Eberhard Quote Link to comment Share on other sites More sharing options...
Sedat Posted October 5, 2013 Author Report Share Posted October 5, 2013 Hi Eberhard, no I mean the sort function in the left catalog panel. If you right click on the folder bar you will see a submenu with additional commands for sorting and expanding or closing the panel. Quote Link to comment Share on other sites More sharing options...
_noel_ Posted October 5, 2013 Report Share Posted October 5, 2013 Hi Eberhard, no I mean the sort function in the left catalog panel. If you right click on the folder bar you will see a submenu with additional commands for sorting and expanding or closing the panel. Strange ... this works also fine with my Daminion standalone 889 installation, with an old and with a new catalog. Quote Link to comment Share on other sites More sharing options...
Murat Posted October 5, 2013 Report Share Posted October 5, 2013 Server or Local catalog? Quote Link to comment Share on other sites More sharing options...
Sedat Posted October 5, 2013 Author Report Share Posted October 5, 2013 Server or Local catalog? This happens on Server catalog. Local catalog is working. Quote Link to comment Share on other sites More sharing options...
