Mammut Posted October 4, 2013 Report Share Posted October 4, 2013 I wanted to change a Custom Tag because it was hierarchical, but I forgot to set the Multiple tag values option. So I deleted the Custom Tag and created it again with those two settings. I wanted to Rescan the folder, because the tags are all gone. And here comes the trouble, every time when I right click on a folder I always get an Object reference not set to an instance of an object error. I tried to change it back, deleted the Custom Tag and created it again only with the hierarchical option. No use. The same error every time. I restarted Daminion but the same error. I deleted all Custom Tags from the Catalog, but the same error. I completely broke that Catalog. I tried to Optimize it, but no use. I can't even Move files to another Catalog, Daminion moves the first file and after that it just stucks there without any progress, cancel does not work either, I had to kill the Daminion process in the taskman. I can reproduce the issue. I tried the whole thing again with an new, empty Catalog, I imported 1 new image (without any tags), I created a new Custom Tag, assigned some tags to the image, saved them, everything was working fine. And then I deleted and re-created the Custom Tag. There was the error right away at right click on the folder. Regards, mammut PS1: I get the error also when I want to quit Daminion. __________________________ PS2: the error code: See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.NullReferenceException: Object reference not set to an instance of an object. at PicaJet.Daminion.ClientCommon.TagSpecifiedTreeViewActions.AppendSpecifiedActions(IIndexedTag indexedTag, IList`1 indexedTagValues, IList`1 actions) in c:\DaminionAuto\Code\ClientCommon\Actions\TagSpecifiedTreeViewActions.cs:line 446 at PicaJet.Daminion.ClientCommon.Actions.IndexedTagTreeViewActionManager.AppendTagSpecified(ICatalogView catalogView, IList`1 indexedTags, IList`1 indexedTagValues, IList`1 actions) in c:\DaminionAuto\Code\ClientCommon\Actions\IndexedTagTreeViewActionManager.cs:line 594 at PicaJet.Daminion.ClientCommon.Actions.IndexedTagTreeViewActionManager.GetActionList() in c:\DaminionAuto\Code\ClientCommon\Actions\IndexedTagTreeViewActionManager.cs:line 221 at PicaJet.Daminion.ClientCommon.PicaJetEnginePresenter.CatalogIndexedTagsViewLaunchContextMenu(Object sender, LocationEventArgs e) in c:\DaminionAuto\Code\ClientCommon\Presenters\PicaJetEnginePresenter.cs:line 5401 at PicaJet.Daminion.GUIComponents.IndexedTagsTreeViewContainer.DoLauchContextMenu(Point p) in c:\DaminionAuto\Code\GUIComponents\Controls\IndexedTagsTreeViewContainer.cs:line 1162 at PicaJet.Daminion.GUIComponents.IndexedTagsTreeViewContainer.IndexedTagsTreeViewOnRightMouseClickNode(Object sender, MouseEventArgs e) in c:\DaminionAuto\Code\GUIComponents\Controls\IndexedTagsTreeViewContainer.cs:line 1155 at PicaJet.Daminion.GUIComponents.TreeViewWithStateControl.OnNodeMouseClick(TreeNodeMouseClickEventArgs e) in c:\DaminionAuto\Code\GUIComponents\Controls\TreeViewWithStateControl.cs:line 1462 at System.Windows.Forms.TreeView.WmNotify(Message& m) at System.Windows.Forms.TreeView.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5448 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- Daminion Assembly Version: 2.0.0.888 Win32 Version: 2.0.0.888 CodeBase: file:///C:/Program%20Files/Daminion%20Software/Daminion/Daminion.exe ---------------------------------------- Quote Link to comment Share on other sites More sharing options...
Murat Posted October 4, 2013 Report Share Posted October 4, 2013 Thanks for the info! Added to the bug-fixing queue. Quote Link to comment Share on other sites More sharing options...
Murat Posted October 9, 2013 Report Share Posted October 9, 2013 Fixed. Quote Link to comment Share on other sites More sharing options...
Mammut Posted October 9, 2013 Author Report Share Posted October 9, 2013 Great, thanks. Quote Link to comment Share on other sites More sharing options...
