875 Layout small issue
exterminador
I wanted to report this small issue.
When in the "Details" view, if the displayed list is long enough to need a vertical and horizonal scroll, if you scroll down to the bottom of the list, the horizontal scroll bar hides the last item in the list (you can select it with the keyboard for example, but you cannot see it in the pane).
Adding a screenshot to help explain myself.
Thanks!
Thanks for the info. Great screenshot, by the way. You imported more than 1 million files to Daminion
:clapping::yess::good:
Thanks Murat, yes! and it works great! To be honest, I tried a lot of products (popular and unpopular) before finding Daminion and none of them was usable with that amount of files, considering it runs on a regular/affordable PC.
