exterminador Posted June 25, 2013 Report Share Posted June 25, 2013 Hi, I'm not sure if this is the expected behavior or not, is it? When using the Catalog Tags panel to assign a tag, it always activate the assign mode even if "Enable Assign Mode after each Tag Assignment" is not enabled. Steps to reproduce: 1. click on the mesh icon (top right of the "Catalog Tags" panel) 2. uncheck "Enable Assign Mode after each Tag Assignment" 3. select a picture on the main panel 4. right click a tag on the "Catalog Tags" panel (i.e. People) and select "Assign 'People Name' to selected items" 5. the assign mode is activated and have to push the "Return to Filter Mode" button Thanks! Quote Link to comment Share on other sites More sharing options...
Murat Posted June 26, 2013 Report Share Posted June 26, 2013 Will be fixed (#2712). "Enable Assign Mode after each Tag Assignment" works now only when you drag the images to a tag. But not visa verse. Quote Link to comment Share on other sites More sharing options...
