AdiBoy Posted April 1, 2013 Report Share Posted April 1, 2013 I have been running 0.9.7.675 with no problems, but hadn't used it for a while. When I started it up today, it prompted me to download 0.9.9.731 which I did. However, when I tried to install it, the installation froze while trying to install .NET components. I had to stop the installation using the task manager. I tried several times, but with no success. Fortunately, I still had the installation file for 0.9.7.675, but obviously I would prefer to use the latest beta. I am using Windows 8 64 bit Quote Link to comment Share on other sites More sharing options...
Murat Posted April 2, 2013 Report Share Posted April 2, 2013 I have been running 0.9.7.675 with no problems, but hadn't used it for a while. When I started it up today, it prompted me to download 0.9.9.731 which I did. However, when I tried to install it, the installation froze while trying to install .NET components. I had to stop the installation using the task manager. I tried several times, but with no success. Fortunately, I still had the installation file for 0.9.7.675, but obviously I would prefer to use the latest beta. Can you give us a remote access by TeamViewer to your PC to check this issue? Quote Link to comment Share on other sites More sharing options...
AdiBoy Posted April 2, 2013 Author Report Share Posted April 2, 2013 Can you give us a remote access by TeamViewer to your PC to check this issue? Yes. Tell me how. Quote Link to comment Share on other sites More sharing options...
Murat Posted April 2, 2013 Report Share Posted April 2, 2013 Sent the private message with the necessary information Quote Link to comment Share on other sites More sharing options...
