Richard Posted February 4, 2013 Report Share Posted February 4, 2013 Add string of keywords to a batch of images We would like to add a string of keywords to a batch of images. There are twelve keywords in the string. The words are comma-separated. Most of the words are showing up in the images but some are not. For example the word 'history' is not accepted in the batch processing. Maybe the forum has an idea on how to solve the issue? Thanks in advance for your time and attention, Richard Quote Link to comment Share on other sites More sharing options...
Murat Posted February 4, 2013 Report Share Posted February 4, 2013 Hi Richard, A sample list of steps: 1. Update to Daminion 0.9.9.721 version 2. Launch Daminion, open a catalog and select images 3. Go to the Properties panel and click on the "Click here to display union..." if you selected more than 20 files 4. Locate the "Keywords" tag, right click and select "Paste" option from the appeared context menu. 5. Press Save button. Alternatively, you can append a set of new keywords by creating a Tag Preset. Assigned a Tag Preset will append new keywords to an existing keywords of each selected image. Hope this helps. For example the word 'history' is not accepted in the batch processing. Could you please explain in detail, what did you mean here? Quote Link to comment Share on other sites More sharing options...
Richard Posted February 4, 2013 Author Report Share Posted February 4, 2013 Hi Murat, In Daminion 0.9.9.721 version the issue is solved. Thanks! The keywords are placed in an alphabetical order. We would like to achieve that our additional string of keywords is placed at the end of the word string. How we have to proceed to achieve this? Thanks for your time and attention. Hi Richard, A sample list of steps: 1. Update to Daminion 0.9.9.721 version 2. Launch Daminion, open a catalog and select images 3. Go to the Properties panel and click on the "Click here to display union..." if you selected more than 20 files 4. Locate the "Keywords" tag, right click and select "Paste" option from the appeared context menu. 5. Press Save button. Alternatively, you can append a set of new keywords by creating a Tag Preset. Assigned a Tag Preset will append new keywords to an existing keywords of each selected image. Hope this helps. Could you please explain in detail, what did you mean here? Quote Link to comment Share on other sites More sharing options...
Murat Posted February 4, 2013 Report Share Posted February 4, 2013 The keywords are placed in an alphabetical order. We would like to achieve that our additional string of keywords is placed at the end of the word string. How we have to proceed to achieve this? According to the XMP/MWG specification that Daminion follows, Keywords is a tag with un-ordered array values. It means that we don't store their order and you can't change it. Quote Link to comment Share on other sites More sharing options...
