kingsfan Posted July 23, 2011 Report Share Posted July 23, 2011 Repro steps: 1. Using CR2 or ORF file (not tested with other RAW formats), assign a People tag to an image. 2. Verify using EXIFTOOL that xmp:PersonInImage tag got populated corectly. 3. Remove the same person from the same image. 4. Verify using EXIFTOOL that xmp:personinimage tag is STILL populated with the original value. Let me know if additonal details are required. I am using the latest public beta. Quote Link to comment Share on other sites More sharing options...
Murat Posted July 25, 2011 Report Share Posted July 25, 2011 Fixed. Thank you! There was a problem in the ExifTool wrapper code that ignores the empty fields from saving into the file. Quote Link to comment Share on other sites More sharing options...
kingsfan Posted July 27, 2011 Author Report Share Posted July 27, 2011 Thanks - eagerly awaiting the next build to try this out. I hope the same wrapper code logic is implemented for other tags as well :-). Quote Link to comment Share on other sites More sharing options...
Murat Posted July 27, 2011 Report Share Posted July 27, 2011 Yes. The problem with other empty tags will be fixed also. Quote Link to comment Share on other sites More sharing options...
