franky68 Posted July 21, 2011 Report Share Posted July 21, 2011 Hello, I just tried to play a little with the Daminion SDK and had no luck. While I can load the library itself I was not able to access any properties/methods. Then I checked with the DLL Export Viewer (http://www.nirsoft.net/utils/dll_export_viewer.html) and it did not list any exports at all. I have to admit I aways avoid MS compilers so I am not familar with .NET but is there any way to access the SDK from other languages? So far I tried with FPC/Lazarus/Delphi. Kind regards Frank Quote Link to comment Share on other sites More sharing options...
Murat Posted July 21, 2011 Report Share Posted July 21, 2011 Daminion add-ons can be written in any .NET compliant language. If you prefer Delphi you need to use Delphi.NET version. But if you familiar with Delphi it's not a big problem to learn C#. We chose C# + VS over Delphi platform when started Daminion project a few years ago. Daminion.API.dll from Daminion SDK is a .NET class library, so you can see it's methods and classes from .NET IDE like Visual Studio. GMail Addon - is a sample of Daminion Export addon with C# sources. It allows to email pictures directly via Gmail account. Quote Link to comment Share on other sites More sharing options...
