ybo117 Posted December 27, 2012 Report Share Posted December 27, 2012 Hi Murat, I have removed older version to test build 699, and started with a new catalog. I have found some problems: 1. import procedure: the rename template uses %Filename instead of %basename 2. when importing raw files having metadata stored in .xmp files (created from Daminion) it works ok for .NEF /.PEF files but for Fujifilm .RAF files, the tags are not imported. The 'Read tags from file' has no effect. 3. when removing an image file from the catalog it is impossible to import it again. I have the problem with jpegs and raw files. Best regards, Yves Bopp Quote Link to comment Share on other sites More sharing options...
Murat Posted December 27, 2012 Report Share Posted December 27, 2012 1. import procedure: the rename template uses %Filename instead of %basename Unable to reproduce. Could you please show me your rename templates or a screenshot of your Import window. 2. when importing raw files having metadata stored in .xmp files (created from Daminion) it works ok for .NEF /.PEF files but for Fujifilm .RAF files, the tags are not imported. The 'Read tags from file' has no effect. Could you please create a new test local catalog and import a few .RAF files to this catalog. Do you see the tags from .xmp sidecars? 3. when removing an image file from the catalog it is impossible to import it again. I have the problem with jpegs and raw files. The problem was fixed in 708 build. Quote Link to comment Share on other sites More sharing options...
ybo117 Posted December 27, 2012 Author Report Share Posted December 27, 2012 Hi Murat, Thanks for your answer. I made the requested tests with build 708. 1. Unable to reproduce. Could you please show me your rename templates or a screenshot of your Import window. 2. Could you please create a new test local catalog and import a few .RAF files to this catalog. Do you see the tags from .xmp sidecars? I can see no tags! The problem was fixed in 708 build. It works ok in 708. Thanks. Best regards, Yves Quote Link to comment Share on other sites More sharing options...
Murat Posted December 28, 2012 Report Share Posted December 28, 2012 Both problems have been fixed. Thanks for the information! Quote Link to comment Share on other sites More sharing options...
Murat Posted December 28, 2012 Report Share Posted December 28, 2012 Daminion 0.9.8.711 Quote Link to comment Share on other sites More sharing options...
