WolfgangO Posted October 20, 2012 Report Share Posted October 20, 2012 I have some Photos from different authors in the same category, for example 300 picts from Paul and 200 picts from Paula, all in the category "Houses". How can I find only the photos from Paul, or better, how can I select this photos with one klick? I have in the catagory houses 500 pictures, for a moment I need only the picts from one author.....Can I create a new Tag "Authors". Quote Link to comment Share on other sites More sharing options...
Murat Posted October 20, 2012 Report Share Posted October 20, 2012 Hi Wolfgang, You need to check the "House" category to display a green radio button. Then hold the Ctrl key and check the Paul author. You will see all the photos taken by Paul in Houses category. To create a new authors right click on the Authors tag in the tags tree and navigate to Create Tag menu option. You can also create and assign new authors via Properties panel. Quote Link to comment Share on other sites More sharing options...
