Problem: Display of cropped RAW images
franky68
I just found a minor issue with the fullpage display/lighttable. When I crop a RAW (NEF) file and update the thumbnail the newly generated thumb looks perfect. However opening the image in the viewer shows the cropped image but with the original dimensions. The image is scaled and stretched if the new aspect ratio is not 2:3 anymore.
Are you displaying the embedded JPEG with the dimensions from the RAW? Is it possible to use the JPEG dimensions instead - at least when Daminion is set to use the embedded preview image?
Kind regards
Frank
  • 1 year later...
