_noel_ Posted September 3, 2012 Report Share Posted September 3, 2012 Hello, Today I started daminion (standalone, newest version) and wanted to load my catalog I was working with last week, but the error below occured. Can anybody help ? I did not alter any drive letters etc. ... See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.Xml.XmlException: Root element is missing. at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.ThrowWithoutLineInfo(String res) at System.Xml.XmlTextReaderImpl.ParseDocumentContent() at System.Xml.XmlTextReaderImpl.Read() at System.Xml.XmlTextReader.Read() at System.Xml.XmlReader.MoveToContent() at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderSortingCriteriaStore.Read4_SortingCriteriaStore() ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400) CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- Quote Link to comment Share on other sites More sharing options...
Murat Posted September 4, 2012 Report Share Posted September 4, 2012 Could you please locate, zip and send me this folder: C:\Users\USERNAME\AppData\Roaming\Daminion Software\Daminion\1.0 After sending this folder, please it and Launch Daminion again. PS. You can also update your Daminion to 602 build Thanks! Quote Link to comment Share on other sites More sharing options...
Mammut Posted September 4, 2012 Report Share Posted September 4, 2012 (edited) PS. You can also update your Daminion to 602 build Hi Murat, off: is there a server version of that build 602, too? Thanks, mammut Edit: Thank you for the links, Murat! Edited September 4, 2012 by Mammut Quote Link to comment Share on other sites More sharing options...
Murat Posted September 4, 2012 Report Share Posted September 4, 2012 Yes. Daminion Server 0.9.5.602 Daminion Standalone 0.9.5.602 Quote Link to comment Share on other sites More sharing options...
_noel_ Posted September 4, 2012 Author Report Share Posted September 4, 2012 Could you please locate, zip and send me this folder: C:\Users\USERNAME\AppData\Roaming\Daminion Software\Daminion\1.0 After sending this folder, please it and Launch Daminion again. PS. You can also update your Daminion to 602 build Thanks! Hello Murat, Here it is: 1.0.zip After renaming the folder, daminion started up from scratch, my old catalog was usable. Now updating to version 0.9.5.602 ... regards Quote Link to comment Share on other sites More sharing options...
Murat Posted September 26, 2012 Report Share Posted September 26, 2012 Fixed with 624 build. Quote Link to comment Share on other sites More sharing options...
_noel_ Posted October 2, 2012 Author Report Share Posted October 2, 2012 Fixed with 624 build. Thanks, the error did not occur any more with 624 & 631 build. Quote Link to comment Share on other sites More sharing options...
