Properties Panel arangement
kalain
After Daminion installation Properties panel is like this (General, Image, Description, System)
If you edit Properties panel and remove a tag (like software) :
You got this (General, Description, Image, System):
But from my point of view, original sorting (General, Image, Description, System) is better than sorting you get after editing. (General, Description, Image, System)
By now, with this 'bug' you have to choose from Original Category sorting (with all default tags) or with a non original category sorting with your tag choice.
Well, in order to give more flexbility and fit to any Daminion user's, it would be nice if Categories position in properties panel could be sorted same way as you can choose tag position in list.
  • Upvote 1
  • 2 months later...
