WilfriedB Posted January 10, 2017 Report Share Posted January 10, 2017 Is this a bug or a feature? When you select an image in the tray and press Ctl+Shift+C, path and file name is indeed copied to the clipboard. However, it is not the path and name of the item selected in the tray, but of the one which is still selected in thumbnail window. Even worse, if you deselect all thumbnails (Edtit > Deselect All), then select an item in the tray and press Ctl+Shift+, you receive an error message: ************** Exception Text ************** System.ArgumentNullException: Value cannot be null. Parameter name: text Quote Link to comment Share on other sites More sharing options...
Alexius Posted January 11, 2017 Report Share Posted January 11, 2017 Thanks for info. Fixed. Will be available at next build. Quote Link to comment Share on other sites More sharing options...
WilfriedB Posted January 11, 2017 Author Report Share Posted January 11, 2017 (edited) Thank you, Alexey! It does work in Build 1586: When I select one or more items in the tray and press CTRL+Shift+C, the full paths of the tray items are copied to the clipboard. Subsequently clicking on an item in the thumbnail window, CTRL+Shift+C will copy the path of that item. Edited January 18, 2017 by Wilfried Quote Link to comment Share on other sites More sharing options...
