Problem displaying EPS/AI thumbnails
Murat
Due to a minor in Daminion installation not all EPS/AI files were rendered properly by the latest Daminion 4.6 build.
Daminion Installation Wizard installed GhostScrirt 9.19 while the program looks for 9.18 version.
You can display quality thumbnails for your EPS/AI files if you install GhostScript 9.18 by this link:
https://github.com/ArtifexSoftware/ghostpdl-downloads/releases/download/gs919/gs919w32.exe
And the update their thumbnails (Item > Actions > Rebuild Thumbnail).
It should work for all new Daminion installations (because the valid path is set on our web-site - and it is fixed now).
