PPCnz Posted May 22, 2011 Report Share Posted May 22, 2011 Our company currently uses PicaJet FX. I have imported a few images from PicaJet into Daminion which all worked fine. When displaying the images as details, only the file name, creation date & file format & size are displayed. The author and keywords in most cases is blank. If I then select an image I can see the author and keywords in the properties window. This is also the case when I view the images as thumbnails (I have the file name, creation date & author displayed under each image). I have found that if I edit some of the image tags, save, exit the folder and then go back into it the author & keywords are then displayed in the detail image view & the thumbnails image view only for the images that I have done some editing on. Is there an other way to solve this problem? Quote Link to comment Share on other sites More sharing options...
Murat Posted May 22, 2011 Report Share Posted May 22, 2011 Greetings, Could you please send me the exported PicaJet's xml file to support [at] daminion [dot] net. -- Regards, Murat Quote Link to comment Share on other sites More sharing options...
