Best Practice For Archiving
John B
Is there anything..
Basically when the nas is full. I want to archive onto hard drives.. of which are stored in a container i.e.. plastic box (designed for storing HDDs)
The catalogue I am using now I have set up an entry space for "Archive Disk" so I can put in the disk number to tell me which disk the file is stored on.. I take it all I have to do is move the file to the disk then enter the number into it the catalogue entry field. But will the catalogue keep all the info and will it auto update the file path. Also the archive disk is encrypted for security.
Please would appreciate any feed back or advise before doing this.. Or would it be wise to create a separate catalogue for each archive drive.? and move the file to new Catalogue as available in the drop down list
Just confused
Thanks
