Mel Posted June 6, 2015 Report Share Posted June 6, 2015 Unfortunately, Daminion does not recognize 32bit dng files created by Camera Raw. Any plans to remove this limitation? -- M.L. Quote Link to comment Share on other sites More sharing options...
Murat Posted June 17, 2015 Report Share Posted June 17, 2015 Can you please send me one of those files to my email? Quote Link to comment Share on other sites More sharing options...
Mel Posted September 15, 2015 Author Report Share Posted September 15, 2015 Can you please send me one of those files to my email? Unfortunately, the preview is still not available (v1280). Any plans...? -- Mariusz Quote Link to comment Share on other sites More sharing options...
Murat Posted October 9, 2015 Report Share Posted October 9, 2015 Can you please resend me this file again? Quote Link to comment Share on other sites More sharing options...
Mel Posted October 9, 2015 Author Report Share Posted October 9, 2015 Can you please resend me this file again? Three dng files of 60 to 100 MB each will be available in dropbox soon (ignore the registration window by clicking cross-mark in upper right corner), uploading now over slow line. The files were created by "Merge to hdr" feature in Adobe Camera Raw. The link: https://www.dropbox.com/sh/yfbv72i561upxme/AAAsP6nJq4ph4fwG84ra1hw_a?dl=0 -- M. Quote Link to comment Share on other sites More sharing options...
Murat Posted October 9, 2015 Report Share Posted October 9, 2015 Thanks for the files. I've tested your files with multiple versions of the DCRAW lib that we use to extract JPEG previews from RAW images and it seems that your DNG files don't contain them. Updated: However I see a JPEG marker inside your image so probably this is the issue of the DCRAW lib. Quote Link to comment Share on other sites More sharing options...
