Mel Posted May 16, 2015 Report Share Posted May 16, 2015 I would suggest a future option to split and merge catalogs. How I see it: There's one large catalog with all my photos. With this option I can split it and extract a set of files maintaining the whole Daminion db structure - tags, etc. Such extracted catalog together with its files lands on a fast SSD drive where all edits and updates takes seconds, not hours. And merge with "master" catalog after job done is self-explanatory. -- M.L. Quote Link to comment Share on other sites More sharing options...
Murat Posted May 16, 2015 Report Share Posted May 16, 2015 You can move files from the first catalog to the second one. Quote Link to comment Share on other sites More sharing options...
Mel Posted May 17, 2015 Author Report Share Posted May 17, 2015 You can move files from the first catalog to the second one. But... how? -- M.L. Quote Link to comment Share on other sites More sharing options...
acorn Posted May 19, 2015 Report Share Posted May 19, 2015 But... how? -- M.L. Hi M.L. -- transferring files between catalogs Download two or more catalogs into Daminion Select one or more files from the first catalog. Right click a highlighted thumbnail. Select 'Move to' from the menu which opens -- this then displays the filepaths of the other catalog(s) Click on the filepath of the destination catalog to transfer the file(s) --- you are asked to confirm this. As a second option you can also find the 'move to' command in the main 'ITEM' menu Hope this helps -- I am using Daminion 4.0 (1213) desktop version P.S. There does not appear to be a 'Copy to' catalog command which would let you retain the chosen files in the source catalog. Quote Link to comment Share on other sites More sharing options...
Mel Posted May 20, 2015 Author Report Share Posted May 20, 2015 Hi M.L. -- transferring files between catalogs Download two or more catalogs into Daminion Select one or more files from the first catalog. ... Thanks. Unfortunately, the flag/reject selection is lost during move so this is not a good solution. There's a menu item File > Import > Daminion Local Catalog (grayed out, I cannot verify what's for) so the logical counterpart would be "Export selected files to new catalog" with all tags in place. (Daminion Desktop the latest) -- Mariusz Quote Link to comment Share on other sites More sharing options...
