VinceBR Posted May 14, 2015 Report Share Posted May 14, 2015 I modified some tags of an image (title, place...) and then exported all the information using ExifTool. Everything is OK, using special characters. I then inserted GPS coordinates using the Map module, and exported again all the metadata information to a text file. ExifTool is not able to read french any more... :wink: 'Procédé' is now 'Procédé' for example. Any reason ? Vince Quote Link to comment Share on other sites More sharing options...
Murat Posted May 16, 2015 Report Share Posted May 16, 2015 Can't reproduce this issue. Do you see 'Procédé' or 'Procédé' via the "Item > Actions > Show All Metadata..." command Quote Link to comment Share on other sites More sharing options...
