peterharvey Posted February 22, 2015 Report Share Posted February 22, 2015 Daminion says I have a large number of duplicates (3,455/18,277). I have scrolled through the thumbnails and found just one. OK, there may be one or two others but I am certain that practically all of these are NOT duplicated. What's going on? Quote Link to comment Share on other sites More sharing options...
Murat Posted February 22, 2015 Report Share Posted February 22, 2015 Hi Peter, - What Daminion version do you have installed? - What tag is selected as the Sort By option? Do you see the issue after changing it to the File Size option? Can you please send me your catalog for analyzing? Quote Link to comment Share on other sites More sharing options...
peterharvey Posted February 23, 2015 Author Report Share Posted February 23, 2015 Version 3.4.0 Build 1111 Filename, Creation Date, and File size. Hi Peter, - What Daminion version do you have installed? - What tag is selected as the Sort By option? Do you see the issue after changing it to the File Size option? Can you please send me your catalog for analyzing? Quote Link to comment Share on other sites More sharing options...
Murat Posted February 24, 2015 Report Share Posted February 24, 2015 Do you see the issue after upgrading to the Daminion 3.4 1113 version and rebuilding the thumbnails? Quote Link to comment Share on other sites More sharing options...
peterharvey Posted February 24, 2015 Author Report Share Posted February 24, 2015 Do you see the issue after upgrading to the Daminion 3.4 1113 version and rebuilding the thumbnails? I can't see anything later than 1111 either in D directly or on https://www.daminion.net/download. Peter Quote Link to comment Share on other sites More sharing options...
peterharvey Posted February 24, 2015 Author Report Share Posted February 24, 2015 Following your comment about the thumbnails I have tried updating some of them and I find that the displayed number of duplicates falls by twice the number of thumbnails I have updated. Quote Link to comment Share on other sites More sharing options...
Murat Posted February 27, 2015 Report Share Posted February 27, 2015 Hi Peter, Can you please send us your catalog file for analyzing to support/at/daminion/dot/net? Quote Link to comment Share on other sites More sharing options...
peterharvey Posted February 28, 2015 Author Report Share Posted February 28, 2015 Thanks Murat but I've updated all the thumbnails and that solved the problem. Quote Link to comment Share on other sites More sharing options...
