How to display quality thumbnails of AutoCAD (DWG/DXF) drawings
Murat
Daminion can import AutoCAD DWG and DXF files but displays the default icon for them that makes difficult to find the right drawings visually.
However if you'll download and install the free DWG TrueView from the AutoDesk you can see the quality thumbnails of your drawings not only in the Daminion but also in the Windows Explorer.
Thumbnails with default AutoCAD icon should be rebuilded from the Daminion's menu:
Item > Rebuild Thumbnail (Ctrl + B)
