equifoto Posted August 5, 2014 Report Share Posted August 5, 2014 Finding duplicates does not work for me I create 4 file with diffent extentions it did not work also the cameralens info is incorrect all images are shot with same lens. please send PM is org files are needed Quote Link to comment Share on other sites More sharing options...
Murat Posted August 5, 2014 Report Share Posted August 5, 2014 Could you please drop me those images to the support/at/daminion/dot/net. Quote Link to comment Share on other sites More sharing options...
equifoto Posted August 5, 2014 Author Report Share Posted August 5, 2014 A wetransfer is on thevway Quote Link to comment Share on other sites More sharing options...
Murat Posted August 5, 2014 Report Share Posted August 5, 2014 Thanks for the files. Daminion's Finding Duplicates feature find 100% identical images only but without taking into account the metadata part. However the colors of images you sent me are slightly differ and Daminion treats them as different images. Hope we'll improve this feature in the future Daminion versions so you can find duplicates with a specified thresould. Quote Link to comment Share on other sites More sharing options...
equifoto Posted August 7, 2014 Author Report Share Posted August 7, 2014 How are they different because the nef file is loaded in cs6 And exported to psd,tiff and jpg No chances are made Quote Link to comment Share on other sites More sharing options...
Murat Posted August 19, 2014 Report Share Posted August 19, 2014 While the picture is the same it seems that CS6 applied different color conversion when saving those images. Quote Link to comment Share on other sites More sharing options...
