franky68 Posted November 2, 2011 Report Share Posted November 2, 2011 Hello Murat, I exported a couple of images using "Export to" -> "Copy to folder" from Daminion. The resulting images partially have the wrong orientation. This applies to the images that should have a portrait orientation. Some of them are correct, some are upside down and a few are landscaped... All images are displayed correctly in Daminion. Example: DSC_9317.JPG portrait, displayed correctly in Daminion, reported proportion "Vertical", Exif: Orientation: Rotate 270 CW Exported image: Landscape D30_4961.NEF portrait, displayed correctly in Daminion, reported proportion "Vertical", Exif: Orientation: Rotate 270 CW Exported image: Upside down Quote Link to comment Share on other sites More sharing options...
Murat Posted November 3, 2011 Report Share Posted November 3, 2011 Fixed. Thank you, Frank! I noticed that the problem occurred when the "JPEG Original Size" preset was selected. Could you please send me these two files for an extra testing? Quote Link to comment Share on other sites More sharing options...
franky68 Posted November 3, 2011 Author Report Share Posted November 3, 2011 Hello Murat, thanks! And youre correct: I forgot to mention that I had "orginal size" selected. The mentioned images are in your mailbox. Quote Link to comment Share on other sites More sharing options...
Murat Posted November 3, 2011 Report Share Posted November 3, 2011 I've checked the files you send me and they are correctly rotated on the working Daminion version (that will be available soon). Quote Link to comment Share on other sites More sharing options...
