alex.l Posted August 14, 2013 Report Share Posted August 14, 2013 Hei I'm evaluation Daminion and just imported 400 images.All images ar Nikon Raw NEF files. All thumbnails are OK but for some images it will only show the upper 30% of the image, when showing it full screen. Zooming out still shows only 1/3 of the image. Anybody seen this problem before? I could mail the image if needed I'm running the 1.0 build 833 on W7 x64. I have FastPictureViewer Codec PAck 3.4.0.77 installed too.This hasn't been giving me problems before but maybe it clashes with the codec Daminion uses... cheers Alex Quote Link to comment Share on other sites More sharing options...
Murat Posted August 14, 2013 Report Share Posted August 14, 2013 Please send us a few sample images that are incorrectly shown to support/at/daminion.net Did you crop these images in someway using a RAW editor? Quote Link to comment Share on other sites More sharing options...
Murat Posted August 14, 2013 Report Share Posted August 14, 2013 Thanks for sending me your images. This is a known problem: it appears when you try to view cropped RAW images, and when cropped orientation is differ than original RAW image orientation. For example, your cropped part has Portrait orientation, while an original RAW image taken in Album orientation. Quote Link to comment Share on other sites More sharing options...
alex.l Posted August 14, 2013 Author Report Share Posted August 14, 2013 HI That is correct I checked and it was in landscape mode but i cropped it to a portrait sized image. Is this going to be solved in the final release? Quote Link to comment Share on other sites More sharing options...
Murat Posted August 14, 2013 Report Share Posted August 14, 2013 Can't say cause the feature queue is large enough but we'll try to fix it soon. Quote Link to comment Share on other sites More sharing options...
J.D. McDowell Posted September 10, 2013 Report Share Posted September 10, 2013 I too am experiencing various viewer issues with NEF files. Tall cropped files are only showing the upper part of the image. Wide cropped files are displaying with odd aspect ratios (too tall, but not full screen.) All the thumbnails look fine. "This is a known problem: it appears when you try to view cropped RAW images, and when cropped orientation is differ than original RAW image orientation." This does not explain the observed behaviour in all cases. Build 875. Quote Link to comment Share on other sites More sharing options...
Murat Posted September 11, 2013 Report Share Posted September 11, 2013 Will be fixed soon. Quote Link to comment Share on other sites More sharing options...
J.D. McDowell Posted September 12, 2013 Report Share Posted September 12, 2013 Will be fixed soon. Excellent!. Thanks. Quote Link to comment Share on other sites More sharing options...
