831 - Problems with Check Out
Herb
I am working with Daminion standalone 1.0.0.831.
With this version I started to "play" with checking out images, but got lots of problems.
When I try to check out an image, I always get the error message: Unable to find 'Checked Out to Me' value.
The image seems to be checked out, because it is copied into the subdirectory ~Versions.
The menu entry 'Check In' is always disabled.
With history menu 'Save Revision as' an unhandled exception "Method or operation is not implemented" is thrown.
I hope you can reproduce the problem(s).
Best regards
Herb
