The Crooner Posted April 17, 2013 Report Share Posted April 17, 2013 When using advanced search, and searching by date, the drop down box is not wide enough to show the whole date, only the first two digits of year are displayed leading to easy errors in search criteria. which are only apparent after the search is completed. Tony Edit - does not apply only to date, the box needs to grow to accommodate any search string. Quote Link to comment Share on other sites More sharing options...
Murat Posted April 17, 2013 Report Share Posted April 17, 2013 What Daminion version do you use? Can you please post a screenshot here or send it me to support at daminion.net? Quote Link to comment Share on other sites More sharing options...
The Crooner Posted April 17, 2013 Author Report Share Posted April 17, 2013 With pleasure 1.0.0 build 777 Quote Link to comment Share on other sites More sharing options...
Murat Posted April 17, 2013 Report Share Posted April 17, 2013 You can enlarge the search window width a bit. We'll change the default window width a bit. Thanks! Quote Link to comment Share on other sites More sharing options...
The Crooner Posted April 17, 2013 Author Report Share Posted April 17, 2013 Thank you. I did not realise the dialogue box could be expanded - now I know it works fine and I feel a bit stupid! However for best "look and feel" I think it should by default be bigger as you intend, or auto-grow. Thanks again Tony Quote Link to comment Share on other sites More sharing options...
