_noel_ Posted April 7, 2013 Report Share Posted April 7, 2013 I have discovered memory leaks in full screen view: after scrolling through about 200 images (JPGs, NEFs, DNGs) no more images can be shown, an error message appears. Daminion has 1,6-1,8 GB memory (Working set & private working set) in task manager "User objects" are also constanty increasing with every image shown in the viewer after restarting Daminion everything is ok. Regards Eberhard btw: "-log_enabled" startup parameter does not write any logs with v766 ? Quote Link to comment Share on other sites More sharing options...
Murat Posted April 7, 2013 Report Share Posted April 7, 2013 Eberhard, I'll check this on the next week. Thanks for the info! Does the problem can be reproduced when viewing JPEG images only? You need to use the "-log_enable" parameter instead of the "-log_enabled". Quote Link to comment Share on other sites More sharing options...
_noel_ Posted April 7, 2013 Author Report Share Posted April 7, 2013 Does the problem can be reproduced when viewing JPEG images only? Yes, with "JPGs only" also: the bigger the JPGs the more increases the memory (and user object also growing with JPGs) Quote Link to comment Share on other sites More sharing options...
Murat Posted April 12, 2013 Report Share Posted April 12, 2013 Could you please check the issue with the latest 776 build There should be small memory leaks, due to a thumbnail cache and a minor issue that will be fixed to the next major update. But the problem shouldn't be so critical now. But anyway I am waiting for your response Quote Link to comment Share on other sites More sharing options...
_noel_ Posted April 12, 2013 Author Report Share Posted April 12, 2013 Mem and User objects look better now, but performance is still an issue, but this was mentioned in other threads. Quote Link to comment Share on other sites More sharing options...
