Separate IIS installation for Home Server
kingsfan
With Daminion Home Server, is it possible to use an existing IIS instance on a server that is separate from the server where the Daminion Home Server bits are installed? I'm trying not to have mutliple IIS instances running on the home network - thus I ask.
Thanks.
On 5/5/2023 at 8:41 PM, kingsfan said:
Thanks.
Hello,Daminion Server must be installed on the server where IIS stands. There is no way to separate them.
