Bug: Impossible to start Daminion without Internet connection
GNipp
Warnung
Fehler beim Öffnen des Katalogs
Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
   bei PicaJet.Daminion.ClientCommon.PicaJetEnginePresenter.ConnectingServerJob(Object sender, TimeLessJobEventArgs args) in C:\DaminionAutoGit\code\ClientCommon\Presenters\PicaJetEnginePresenter.cs:Zeile 9557.
OK
This message appears, if Daminion client is started without having web connection.
After confirmation, the Catalogue choice dialog opens.
Selecting and opening a cataloque leads to the same message.
The web-client is also not pausing on the spinner display as if the web request fails.
I'm going to analyse the web protocoll (again) to verify if request are sent to some server outside of the local network.
Installed Version: Server and client: 7.0.0.2457, PostgreSQL 12 64 bit/5432
Funfact: Version check dialogue shows Current: 7.0.0.2457, online available: 7.0.0.2444 (older than the used one?)
Hello.
 Can you share with me more information about your problem?
What type of installation are you used, according this page https://daminion.net/tutorial/selecting-the-right-file-storage-scheme-for-daminion-server/
How do you interrupting a web connection?
And please check firewall rules, maybe Daminion Service blocked.
About Funfact, we don't have a standalone version now and for an update client you need an update daminion server. That's why the new version is older. I think we need to disable this message.
