2344 (Solved) - 2120 - EXIF:XPKeywords not updated
Uwe
If I move a subtag "SUB1" (e.g. MAIN->SUB1) in the Catalog Tags Panel to another main tag (MAIN1->SUB1): the existing EXIF:XPKeywords tag of the files is not updated and has still the old subtag information (MAIN->SUB1). All other tags in the files (XMP, IPTC) regarding the keywords are updated with the new tag hierarchy information.
  • 7 months later...
It's working now with build 2344.
But there is a difference in the metadata. The tags in "XMP:Hierarchical Subject" are separated by ", " (comma and space) but in Exif:XPKeywords the tags are separated by ";". If I call the ExifTool command "-overwrite_original  "-exif:XPKeywords<xmp:HierarchicalSubject" {Filename}" in the "open with..." action both tags and the separators ", " are equal but this leads to problems when you call "read tags from file" or "Rescan folders". you get "to many and wrong" Keyword tags.
One has to use the ExifTool command:  "-overwrite_original  -sep ";" "-exif:XPKeywords<xmp:HierarchicalSubject" {Filename}" because of the different syntax of the XPKeywords tag.
Edited by Uwe
";" and not "*" and command line ExifTool -sep ";"
  • Uwe changed the title to 2344 (Solved) - 2120 - EXIF:XPKeywords not updated
